336D
My tachometer stopped working any suggestions??
Any noise? If the problem is internal to the tach it was likely preceded by screeching.
Trace the cable from behind the tach down to the engine, be sure both ends are attached.
Inside the visible outer sheath is a wire that is rotated by the engine. You can detach the upper end and verify that the core spins when the engine is running.
/ 336D #3
Here's a photo of the underside of the dashboard on a smaller Yanmar. I had to remove it to replace the steering box on a prior YM186D.
This may give you some idea of what's under there, that you can only feel with your fingertips. A tiny miniature version of water pump pliers works well to detach the tach cable.
p1640417ym186drundersidedashboard-jpg.280630
SKID STEER PLATE GRABBER (A62613)
SKID STEER PLATE...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
3148 (A63117)
3148 (A63117)
2011 FORD F-150 (A65643)
2011 FORD F-150...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
