336D
My tachometer stopped working any suggestions??
Any noise? If the problem is internal to the tach it was likely preceded by screeching.
Trace the cable from behind the tach down to the engine, be sure both ends are attached.
Inside the visible outer sheath is a wire that is rotated by the engine. You can detach the upper end and verify that the core spins when the engine is running.
/ 336D #3
Here's a photo of the underside of the dashboard on a smaller Yanmar. I had to remove it to replace the steering box on a prior YM186D.
This may give you some idea of what's under there, that you can only feel with your fingertips. A tiny miniature version of water pump pliers works well to detach the tach cable.
p1640417ym186drundersidedashboard-jpg.280630
2013 ISUZU NQR 4X2 REFRIGERATED BOX (A59909)
2013 ISUZU NQR 4X2...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
PALLET OF APPROX (10) SCISSOR LIFT CONTROLLERS (A62131)
PALLET OF APPROX...
(2) BUNDLE OF MISC SIZE USED TIN UP TO 31' LONG (A62131)
(2) BUNDLE OF MISC...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
