Buying Advice 3320 private purchase
/ 3320 private purchase
Will and thanks. Yes I do not have a clue about operation. Thank God a great farm family is working the front 22 acres and has been for 10 years (on this land).
Their son is meeting me Saturday and he is going to instruct. They are an all JD family from the small ATV to the huge whatevers! They also help me with best management practices.
I will send photos of the equipment and a few of the land. It is a mix of open crop land, brush (thick), scrub (thicker), area with trees 150' high and river.
/ 3320 private purchase #22
Hey, this sounds like a great resource for you.
Congrats and best wishes with your tractor. You got a good one.:thumbsup:
/ 3320 private purchase #23
Congrats on the new to you 3320.
Check how your wheels / tires are mounted and consider switching them to the "wide" setting for greater stability. Loaded tires / wheel weights / ballast are other items you may wish to research depending on your terrain and intended use.
The land is sandy loam which quickly turns soft and slick in rain (or dew). all has ground cover of some type except the 22 acres just harvested of corn and soon to be in winter wheat before soybeans in the spring.
What are situations for the wider wheels and ballast?
I will be going into thick scrub and saplings but plan to use a rented BobCat (T320) with Forestry Cutter to clean a path of about 1.5 miles to the river. Afterward I will keep the path and other trails plus open areas clear with the JD.
I need to connect a lot of old ditches as they start and stop creating areas of polled or flowing water. I will send pictures and video (if not to big) to show the area.
Thanks,
sfloggie
Jim
/ 3320 private purchase #26
Thanks,
sfloggie
Jim
That's a good project right there.
Looing forward to the documentary.:thumbsup:
I can not believe the amount of great information and observations received in this thread and others. In fact I am amazed. Advice given such as where the stems are as relates to narrow or not is something I would have not learned for a while..if ever.
I was raised on a farm but did not pay attention... Now I know how hard and smart my Dad worked. I will keep you informed of my progress..not to show off, but receive correction where need be.
Hope those who vote (as I would like) vote today!
500 BBL WHEELED FRAC TANK (A67714)
500 BBL WHEELED...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
CAT 416F 36" Bucket (A68134)
CAT 416F 36"...
Generator (A64553)
Generator (A64553)
