3320 faster in reverse
/ 3320 faster in reverse #1
Bspring
SC
My 3320 ehydro has been loosing MPH. The manual says in range "A" at 2600 RPM I should run at 3.8 MPH. I have tested range "A" and "B", both fail the test unless I run in reverse. The best I got in range "A" was 2.6 MPH. It is due for a fluid change but it is not over due or low and the air filter is clean. Could this be a calibration issue?
/ 3320 faster in reverse #2
How close is it in range B and range C ?
About 3 MPH off in "B". I have not tested "C".
Problem solved. I had to calibrate the sensor under the pedal.
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
Unverferth 235 Seed Tender Wagon (A64047)
Unverferth 235...
2024 DODGE TRUCK BED (A63569)
2024 DODGE TRUCK...
JLG Scissor Lift (A64047)
JLG Scissor Lift...
2019 Maxx-D 40' Gooseneck Trailer w/ Mega Ramps (A64047)
2019 Maxx-D 40'...
