3320 faster in reverse
/ 3320 faster in reverse #1
Bspring
SC
My 3320 ehydro has been loosing MPH. The manual says in range "A" at 2600 RPM I should run at 3.8 MPH. I have tested range "A" and "B", both fail the test unless I run in reverse. The best I got in range "A" was 2.6 MPH. It is due for a fluid change but it is not over due or low and the air filter is clean. Could this be a calibration issue?
/ 3320 faster in reverse #2
How close is it in range B and range C ?
About 3 MPH off in "B". I have not tested "C".
Problem solved. I had to calibrate the sensor under the pedal.
2023 Stearling Trailer (A60352)
2023 Stearling...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2008 Yale GLP070VXE 6,500lb Propane Forklift (A61572)
2008 Yale...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
