3320 digital display SHORT-D & LONG-D
/ 3320 digital display SHORT-D & LONG-D #1
pokerboy57
John Deere 3320
I own a 3320 . There is a switch which cycles through different information on the LCD display. Anyone know what SHORT-D and LONG-D means ?
/ 3320 digital display SHORT-D & LONG-D #2
Factory defaults for LoadMatch function. See OM for instructions how to reset.
/ 3320 digital display SHORT-D & LONG-D #3
I believe it is MotionMatch;
From the OM.
Changing MotionMatch Setting
1. Press and hold the display mode switch until the display reads "Release"
2. Release the display mode switch and display should read "Coast"
3. Press the display mode switch once again.
4. For machines without MotionMatch switch:
a. Push the turn signal switch and return to neutral position to change to
desired setting between 1 and 9. Position 5 is displayed as "DEF" the
factory default.
5. For machines with MotionMatch switch:
desired setting between 5 and 9. Position 5 is displayed as "LONG_D" the
factory default.
b. Push the turn signal switch and return to neutral position to change to
desired setting between 1 and 5. Position 5 is displayed as "SHRT_D" the
factory default.
6. To confirm the changes for MotionMatch setting, press display mode
switch once again.
