3320 Canopy
/ 3320 Canopy #1
jd670
Kentucky
John Deere 3320 - gator cx - JD 425
Just finished installing a Tuff Top canopy on my 3320. Turned out really well. I painted it JD green to better match the tractor. Pretty quality construction. Like the idea of being able to take it off and on. I still have to glue the sound pad in place. Makes a huge difference brushhogging .
/ 3320 Canopy #2
Looks good. I'd be afraid of catching limbs when in the woods and causing some damage.
Thanks for showing it to us.
/ 3320 Canopy
Yes, I agree. I have a lot of wooded area on my property. I mainly got it to brush hog a wide open 5-acre field. I'll remove it when I go in the woods.
/ 3320 Canopy #4
My first experience with a canopy, was with my 1970 something Ford 2110, that had a huge fiberglass rops canopy on it. That was very nice on hot summer days, when out on the open fields. It was also nice in the rain. The front corners did sustain a little damage from trees, when operating in the woods, or too close to the hedgerows.
I replaced that tractor, with my JD 4120, in 2005. It didn’t take me long to realize that I needed a canopy for that. I made one that same year, with a wood frame, canvas top, and metal support rods.
It’s now on its second canvas, which was given to me by my brother in law, when he scrapped out his old tent camper. The first canvas was made from an old brown-duck boat cover that I got at garage sale got $ 5.
I made the wood frame from scrap lumber, that I had in the barn, and the metal supports were cut from an old fertilizer spreader. It took me about an hour to make this canopy. It has held up quite well for the last 18 years.
I made it about the same size as the one on my old Ford, but I gave it a little more depth, so that it works better when the sun is at lower angles. I also tapered it towards the front, so that it clears and deflects overhead branches better.
The canvas over wood construction is also significantly lighter than the fiberglass, making it easy to put on and take off, with just one arm.
I leave it on the tractor from spring thru fall, and only remove it in the winter, when I use the tractor for snow plowing. I take it off then, so that I can fold the roll-bar down and get the tractor into regular, car-sized garage doors.
/ 3320 Canopy
Nice job. Some serious logs you're carrying. Just finished a 6-acre field yesterday. glad I had it on. Huge difference.
/ 3320 Canopy #6
Have the same one on one of my Kubota M9's and I run hay (rake with it). never had an issue in 4 years. Did not know they had a sound pad. Have to get one. Nice lids and the color matches perfectly too.
/ 3320 Canopy #7
I have the heavy duty bucket on the 400X loader on my 4120. That, and the block heater, are the only “options” it has on it. For forks, I just use a couple lengths of heavy 3” angle iron.
They worked very well for many years, but I must have ran into something while I was Bush-hogging and I bent one up the other day. I had another length of angle iron on my scrap pile, so I made a new one for it.
I also bolt a piece of heavy 12” wide C-channel under the bucket sometimes, when I need to dig ditches or transplant trees. It works real good for that.
As far as the canopy goes, I think they’d sell a lot less cabs, if folks knew how good canopies work under the hot sun. I work in a factory all week. You couldn’t pay me to own a canopy tractor. I love my “outside time” on the tractor after work and on the weekends. I probably wouldn’t on sunny days, were it not for that canopy.
/ 3320 Canopy #9
As cheap as the Tuff Tops are, makes no sense to home build one
They look to be a bit a on the small side, to be very effective, when the sun is at much of an angle.
/ 3320 Canopy
Mine is 52"x52". Pretty good coverage. If sun is just clearing tree line, yea it hits you in face. Once it's it up a little, you're covered. At least this time I didn't get sun burned. Last year I was glowing red. Price was $263 to my door. So far, I'm happy with it.
2014 CHEVROLET CAPRICE (A66091)
2014 CHEVROLET...
2009 ALLMAND  MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2015 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2015 WINSTON...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2020 MACK DUMPTRUCK (A67714)
2020 MACK...
Unused 2023 Unused Hustler LM260 Swiftblade Tractor Loader Attachment (A66734)
Unused 2023 Unused...
