3235 Governor
/ 3235 Governor #1
Bob_Bainbridge
Platinum Member
NE Ohio
Has anyone had problems with the governor on the Kohler Command 25? My 3235 is acting up and sometimes it stays at idle with full throttle and sometimes won't idle down when the throttle is pulled back. I haven't had time to really look at it but I sprayed some lubricating oil on the linkage which helped a little.
Bob B.
/ 3235 Governor #2
Mine has been finicky since day one in that idle speed has never been consistent, usually on the high side and throttle lever response basically goes; nothing...nothing....nothing and then max governed speed at the end of the throttle lever range. Basically I've got fast idle, max and little in between (2005 model year Kohler Command 20) The myriad of linkages and springs seem to move freely w/out binding and since I only use it a max governed engine speed, I really haven't looked into it!
Joel
/ 3235 Governor #3
First thing check the gov spring to ensure it is in the correct setting (go to kohler wen site for engine info)...spring could be broken or off the position...as far as idle there probably is a set screw on the Gov lever for the carb....again, refer to kohler web site for engine info...good luck!
/ 3235 Governor #4
Mine (I have an '04 GT3235) tends to get sticky when it gets dirty - I hit the linkage with Gumout once or twice a season and it keeps things moving freely.
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2007 50FT T/A 3 CAR HAULER TRAILER (A59914)
2007 50FT T/A 3...
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63688)
2006 Cadillac...
