3225 cub cadet mower
/ 3225 cub cadet mower #1
cliff eberling
alliance ohio
cub cadet 3225
i have a 3225 cub cadet mower diff. full of oil problem when i press on pedel to go tractor jumps up and down ( jurkes ) after get going at fairley good speed it smoses out soone as you stop try to start out it does it again
can anyone help thanks
/ 3225 cub cadet mower #2
How recently have you put fresh oil and a new filter on that ? It could have water in it.
Is it struggling to move? The brakes could be hung up. Pull the HST bypass lever (should be in the back) and see if it rolls smoothly and easily.
Next I'd jack up the rear and see how it does when you hit the peddle with zero load. There may be something broken in there!
/ 3225 cub cadet mower #3
Howdy neighbor and :welcome: to TBN!
I'm a few miles south of you below Canton.
Great advice from Ford tractor. I've seen a dented or clogged hydro filter do the same thing, severely limit hydro flow.
I'd also go in least $$$ order....new filter.....new oil....check brakes....and then lift up rear end and see if it still hangs up.
Good luck!
Kuhn Knight Verti-Maxx 5032 Feed Wagon (A66408)
Kuhn Knight...
Case International 21' Disk Harrow (A64127)
Case International...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
20' Reids Trailer (A62613)
20' Reids Trailer...
(2) New 14-17.5 NHS tires w/ fluid on 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
Spirit Electric Bicycle (A64127)
Spirit Electric...
