3205 cub cadet question
/ 3205 cub cadet question #1
rbig
On my cub cadet, on rare occasions, the clutch pedal sometimes causes it to die. With the clutch pedal in normal operating position, it will sometimes cause it to die.
By pusing in slightly on it, it will run fine. Normally, I can find a position where it will run and get past the problem.
Does anyone know what to check for on this problem? Sounds like maybe a switch or something is being actuated.
/ 3205 cub cadet question #2
yep, could be a switch acting up or a pc of trash caught up just wrong... or possibly a chafed elect. wire someplace along the clutch linkage that get moved/grounded every so often when the clutch linkage is worked. Might be worth your time to drop the deck and slide up underneath with a good trouble light and a helper to work that clutch where you can see in detail what all's going on...?
Thanks. I'll do just that.
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
Adams Nurse Trailer Tank (A63688)
Adams Nurse...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
NEW Wolverine 84" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 84"...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
