3130 GST dripping oil
/ 3130 GST dripping oil #1
willywildes
SF bay area
3130 GST/ CAT D-2
I have a 3130 GST it just passed its second birthday, and it has developed a small drip. where i believe the clutch and trans sections go together. anyone else have this problem? is it covered by the warranty?
WW
/ 3130 GST dripping oil #2
WW,
I'm pretty sure the 3130 carries a three year warranty that should cover the leak you described (bad seal maybe???). I would get that bad boy back to the dealer for some warranty repair ASAP.
Good Luck!
Jeff
/ 3130 GST dripping oil #3
This would be a powertrain warranty issue if it is hydraulic oil or engine oil. Probable suspects are fwd driveshaft seal, or clogged transmission vents.
Thanks for the replys. it looks to be coming from where the sections mate together on the bottom. Just in front of all of the solenoids that change the gears. I will drag it to the shop and have them check it out. thanks again
WW
