3110D Sensor lights
/ 3110D Sensor lights #1
goatpharmerx
Southeast Alabama
Yanmar 3110
My idiot lights *charge, oil, and temp* do not seem to be working is there a way to test them to see it is the bulb, sensor, or wiring is the culprit. On my old 240 I just bypassed and installed some generic guages from the auto parts store, but I would like to make them work on the 3110.
thanks
thanks
/ 3110D Sensor lights #3
Sounds like a fuse. That, 12 volts dc, and ground, is all they have in common.
/ 3110D Sensor lights #4
You were almost right I tracked it down to the fuse box. The fuse was good but the connection was a little rusty. I cleaned it up and now the oil and charge lights are working with the ignition on. The temp light still does not come on at startup. I had read some earlier post and tried testing it by grounding the wire out but nothing happened. The bulb is good b/c I swapped it over to one of the other working sockets. Any Suggestions?????
/ 3110D Sensor lights #7
Be sure you have a goood ground connection, both between the battery and the frame and the dash............other than that, could be bad contacts in the bulbholder, or a break inthe wire to the sender.............both fairly easy to check.
/ 3110D Sensor lights #8
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
2008 Ford F250 (A61573)
2008 Ford F250...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2022 EZ-GO ELITE...
2010 HINO 268 4X2 S/A NON CDL 26FT BOX TRUCK (A59912)
2010 HINO 268 4X2...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
