3054 pto question?
/ 3054 pto question? #1
Agentiron
Northwest Indiana
When looking at the literature on the Kioti site it says that the Lk3054xs has a live pto with dual clutch. Does this mean that if you are hogging, and feel the need to switch gears, when you apply pressure to the clucth it will disengage the hog? Seems to me that some tractors have a clutch that will allow you to partially depress the clutch to switch gears while talking the cluch to the floor will then disengage the pto? Can someone clear this up for me?
Thanks
/ 3054 pto question? #2
</font><font color="blue" class="small">( Seems to me that some tractors have a clutch that will allow you to partially depress the clutch to switch gears while talking the cluch to the floor will then disengage the pto? )</font>
What you mentioned above is a 2 stage clutch setup.
The 3054 works the same way.
Clutch part way down stops tractor-PTO continues to run.
Clutch all the way down stops machine and PTO.
Unused 2023 Monroe-Tufline DS1144T 12ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A68183)
1987 Fruehauf MC...
WARREN POWER SYSTEM LIGHT PLANT (INOPERABLE) (A68842)
WARREN POWER...
PORTAPOTTY (A67714)
PORTAPOTTY (A67714)
DIAMOND TOOLBOX (A68842)
DIAMOND TOOLBOX...
2014 FORD F-150 (A67714)
2014 FORD F-150...
