3054 pto question?
/ 3054 pto question? #1
Agentiron
Northwest Indiana
When looking at the literature on the Kioti site it says that the Lk3054xs has a live pto with dual clutch. Does this mean that if you are hogging, and feel the need to switch gears, when you apply pressure to the clucth it will disengage the hog? Seems to me that some tractors have a clutch that will allow you to partially depress the clutch to switch gears while talking the cluch to the floor will then disengage the pto? Can someone clear this up for me?
Thanks
/ 3054 pto question? #2
</font><font color="blue" class="small">( Seems to me that some tractors have a clutch that will allow you to partially depress the clutch to switch gears while talking the cluch to the floor will then disengage the pto? )</font>
What you mentioned above is a 2 stage clutch setup.
The 3054 works the same way.
Clutch part way down stops tractor-PTO continues to run.
Clutch all the way down stops machine and PTO.
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2014 Crane Carrier Co. Low Entry T/A Rear Loader Garbage Truck (A66736)
2014 Crane Carrier...
Unused 2022 Ideal BB4LD 48in. Box Blade Tractor Attachment (A66734)
Unused 2022 Ideal...
(2) Hakkapelitta 360/80R28 Tires & Rims (A64911)
(2) Hakkapelitta...
WELDING TABLE WITH VISE (A68842)
WELDING TABLE WITH...
