305 Loader Question
/ 305 Loader Question #21
A needle valve will not stop a worn seal from leaking.
If the needle valve is in the work port for the retracted cyl the hyd should hold
Some valves are just better than others.
Different manufacturers may have different leak down rates.
You coulld also try out another valve.
Cub Cadet Pro Z 972 (A64127)
Cub Cadet Pro Z...
2010 Deere 318D (A60462)
2010 Deere 318D...
WACKER NEUSON LIGHT PLANT (A65643)
WACKER NEUSON...
QA 72" Grapple Attachment (A64126)
QA 72" Grapple...
2716SFL (A61567)
2716SFL (A61567)
2016 Bobcat E50 (A64126)
2016 Bobcat E50...
