3046R not so quick attach
/ 3046R not so quick attach #1
BearChamion
JD 5115M
Loader is difficult to get back on and has to be lined up just right. This is difficult given how low the loader frame is on the tractor.
Surely I am not the only one to consider this a design defect?
/ 3046R not so quick attach #2
Make a short video of what you are having a problem with, and likely someone can help you figure it out.
Assume you have the 320R FEL. Here is a video that includes info on this FEL, @ 1:14 and again at 6:14. Mention is made to remove FEL on level ground. Otherwise you may have trouble. Assume you already know that.
The design looks to be the same basic design that has been used since 1998 when I bought my 4300 and 430 FEL. It is a great design for quick off and quick on IMO.
So am thinking it isn't a design defect, just sayin..
What's Changed? The NEW John Deere 12r 22r 32r Loaders - YouTube
/ 3046R not so quick attach #3
I have a 3720 with a 300cx loader, same basic thing you have, and no issue here-certainly not a "defect".
/ 3046R not so quick attach #4
Sometimes it helps to put the tractor in neutral to let it get pulled towards the loader when you install it.
I guess it痴 just me. I値l keep working with it.
2015 Ford F-550 Crew Cab Flatbed Truck with Liftgate (A61573)
2015 Ford F-550...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
