3046R not so quick attach
/ 3046R not so quick attach #1
BearChamion
JD 5115M
Loader is difficult to get back on and has to be lined up just right. This is difficult given how low the loader frame is on the tractor.
Surely I am not the only one to consider this a design defect?
/ 3046R not so quick attach #2
Make a short video of what you are having a problem with, and likely someone can help you figure it out.
Assume you have the 320R FEL. Here is a video that includes info on this FEL, @ 1:14 and again at 6:14. Mention is made to remove FEL on level ground. Otherwise you may have trouble. Assume you already know that.
The design looks to be the same basic design that has been used since 1998 when I bought my 4300 and 430 FEL. It is a great design for quick off and quick on IMO.
So am thinking it isn't a design defect, just sayin..
What's Changed? The NEW John Deere 12r 22r 32r Loaders - YouTube
/ 3046R not so quick attach #3
I have a 3720 with a 300cx loader, same basic thing you have, and no issue here-certainly not a "defect".
/ 3046R not so quick attach #4
Sometimes it helps to put the tractor in neutral to let it get pulled towards the loader when you install it.
I guess it痴 just me. I値l keep working with it.
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2002 Hyster C330B Tandem Smooth Drum Roller (A61572)
2002 Hyster C330B...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
Hydraulic Stump Grinder Mini Skid Steer Attachment (A61572)
Hydraulic Stump...
Bobcat MT85 (A60462)
