3038e neutral safety switch bypass?
   / 3038e neutral safety switch bypass? #1
scootr
Super Member
Temecula California
Kubota MX5200 HST, 773 Bobcat, Cat forklift
Helping a friend with this machine, no start. Finally figured out the more complicated than necessary neutral safety switch is the culprit.
Is it acceptable to bypass the switch on a hydrostatic model? Thanks in advance.
   / 3038e neutral safety switch bypass? #2
Don't see a harm to that. My 4300 HST doesn't have a neutral safety switch. And see no need for it.
   / 3038e neutral safety switch bypass? #3
My LS HST never had one and the one on the Kubota was jumpered some time 17-18 years ago.
   / 3038e neutral safety switch bypass? #4
I guess it depends on what you mean by "acceptable". It is a manufacturer-installed safety feature (like a ROPS) and in the past, you have indicated that you think such features should be used.
"So far so good. That is no guaranty of the future. But you have the choice to not use it. Like not using a seat belt. You do you. It doesn't prevent other people from noticing."
So I guess it is up to you to decide if you want to recommend someone defeat a safety feature that could result in them getting run over by their tractor.
   / 3038e neutral safety switch bypass? #5
Generally, bypassing the neutral safety switch isn't recommended. It's there for a reason, safety. While it might seem like a simple fix, you're removing a crucial safety feature that prevents accidental starting while the machine is in gear.
   / 3038e neutral safety switch bypass? #6
Is that the only feature that prevents tractor movement when starting or are there requirements before tractor will start like operator presence in the seat, clutch being depressed, etc.?
If this is an HST transmission that safety switch also helps reduce load on the starter since wouldn’t be trying to move tractor while starting.
To answer your question… no safety switches are needed till someone gets injured and lawsuits erupt.
The tractor will not try to move until to throttle pedal is depressed.
2005 John Deere 7320 (A60462)
2005 John Deere...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2017 Bobcat T770 Compact Track Loader (A56438)
2017 Bobcat T770...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
