3033r
/ 3033r #1
firefighterjrm
Denton, Maryland
3032e D-140
3033r has arrived very impressed although some small hick ups may satellite radio is not connecting and they have to switch out my bucket for the HD however I did notice the loader controls are really stiff I would assume after time they will free up
/ 3033r #2
If your dealership is like mine, they will make everything right for you. There was a bloke over in Goshen whos cab door didn't quite close right... they worked on it, at his property (2hr drive each way), for three days until it was right.
The long story to that is that their reputation soared. Word-of-mouth is king, here in Tassie.
/ 3033r #3
Mine did loosen up after a while, just like my dealer told me as I mentioned that same thing.
[also make sure your lock lever is all the way open]
/ 3033r
I found these two holes in the floor while cleaning the cab out they are located on the right side if you were sitting in the seat covered with electric tape when it goes into the dealer next week for some minor issues they said they would plug and seal it, on another note worked 12 hours straight putting in a 1.5 mile driveway must say nice to get off the tractor and not feeling death worn over 95 degrees outside but nice and cool in the cab air ride seat and the radio going really has spoiled me... well back to it got another driveway to do...
/ 3033r #5
I plugged mine with rubber stoppers, easy to pull out if you have to. Also there is a hole under the hydro pedals I plugged too, it is a drain hole for water for when you have wet shoes. Will take out when I use it in the snow. Scared a mouse family will come in!
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2014 FORD F-150 (A67714)
2014 FORD F-150...
x (A68191)
x (A68191)
2005 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A66736)
2005 Mack CH613...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2013 HAULMARK ENCLOSED UTILITY TRAILER (A67714)
2013 HAULMARK...
