3033 UNCURL TIME
/ 3033 UNCURL TIME #1
Bill MacKay
Lakeville, Nova Scotia
JD 2320
HAVE A 2016 3033 WITH H160 FEL. UP/DOWN TIME AND CURL TIME ARE FINE BUT WHEN I UNCURL THE BUCKET IT TAKES ITS TIME, ABOUT 7 SECONDS TO GO FROM FULL CURL TO FULL UNCURL. IF ANYONE HAS A SIMILAR SETUP COULD YOU TEST AND POST RESULT.
/ 3033 UNCURL TIME #2
First, disconnect and reconnect the hyd lines to the FEL. Might just be a connector problem.
Are you familiar with the "regen" hydraulic system for the fast curl down ?
/ 3033 UNCURL TIME #3
Two things. Clean and reseat the two hydraulic quick couplers for the curl/dump circuit. If the problem persists, reverse the two hydraulic couplers for the curl/dump and see if the problem switches to the curl function.
/ 3033 UNCURL TIME #4
I don't think mine takes 7 seconds, not sure. I have the same tractor and loader. Read this and see if you locked out regeneration mode. IMG_4160.JPG
Thompson Water Pump Diesel Engine (A66734)
Thompson Water...
PAIR OF FRAC TANK STANDS (A68842)
PAIR OF FRAC TANK...
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
2013 CHEVROLET IMPALA (A66091)
2013 CHEVROLET...
2011 FREIGHTLINER CASCADIA (INOPERABLE) (A67714)
2011 FREIGHTLINER...
2016 John Deere 250G LC Hydraulic Excavator (A66734)
2016 John Deere...
