3033 UNCURL TIME
/ 3033 UNCURL TIME #1
Bill MacKay
Lakeville, Nova Scotia
JD 2320
HAVE A 2016 3033 WITH H160 FEL. UP/DOWN TIME AND CURL TIME ARE FINE BUT WHEN I UNCURL THE BUCKET IT TAKES ITS TIME, ABOUT 7 SECONDS TO GO FROM FULL CURL TO FULL UNCURL. IF ANYONE HAS A SIMILAR SETUP COULD YOU TEST AND POST RESULT.
/ 3033 UNCURL TIME #2
First, disconnect and reconnect the hyd lines to the FEL. Might just be a connector problem.
Are you familiar with the "regen" hydraulic system for the fast curl down ?
/ 3033 UNCURL TIME #3
Two things. Clean and reseat the two hydraulic quick couplers for the curl/dump circuit. If the problem persists, reverse the two hydraulic couplers for the curl/dump and see if the problem switches to the curl function.
/ 3033 UNCURL TIME #4
I don't think mine takes 7 seconds, not sure. I have the same tractor and loader. Read this and see if you locked out regeneration mode. IMG_4160.JPG
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
ALLMAND  MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2005 PETERBILT 379 (A67714)
2005 PETERBILT 379...
Unused 2023 USA Manufacturing Hydraulic Thumb Excavator Attachment (A66734)
Unused 2023 USA...
2013 Dodge Durango SUV (A66738)
2013 Dodge Durango...
2016 CHEVROLET CAPRICE CAR (A66091)
2016 CHEVROLET...
