3032E pto problem
/ 3032E pto problem #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
The pto on my neighbors 3032E won't engage. My knowledge of these newer tractors is limited. I suggested cheeking fuses,seat switch,pto switch. Does this tractor have a pto speed sensor?
Thanks,Jim
/ 3032E pto problem
What linkage are you referring to?
Thanks for reply,Jim
/ 3032E pto problem #4
I am not sure if a 3032e is like my 2025r but there is a lever that controls mid pto, rear pto or both. If that linkage was messed up it could cause problems, like being stuck in between gears. My tractor has a button to push to start the pto, wiring could be a problem for that. Some tractors have a mechanical linkage to a lever instead to turn the pto off and on, that could be messed up.
/ 3032E pto problem
Thanks for reply. I just got back from delivering my neighbor a rd bale of hay. I checked all 6 fuses that I could locate & they were good. I'll advise them of possible linkage.
/ 3032E pto problem #6
If you're looking for something specific let me know. I have the service manual on CD for the 3025/3032/3038.
/ 3032E pto problem
Wibb
Thank you for the offer. Could you tell me which fuse is for pto circuit & where pto relay is located?? I checked all fuses I could locate. I have no experience with this model of tractor. I'm just trying to help this neighbor lady that her husband passed recently.
Thanks,Jim
/ 3032E pto problem #8
I'll check it tonight. Shoot me an email if you want in a PM and I'll get you copies of the pages
/ 3032E pto problem
Please check your inbox I sent you a PM.
Thanks,Jim
/ 3032E pto problem #10
Lots of info sent. I sent the harness showing the solenoid and PTO switch as well as the schematics and switch pinouts. Hopefully that will point to a wiring issue that can be solved easily. If not I can send over the ICC pins behind the cluster and dig deeper. Let me know how it goes. Good luck
/ 3032E pto problem
Wibb
Thank you for sending info.
Jim
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
JOHN BLUE TANK SUB FRAME (A63291)
JOHN BLUE TANK SUB...
2022 EZ-GO ELITE...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
