3032 help
/ 3032 help #1
ericsloan
hamptonville, nc
jinma 354 le
I have a 3032 and in need od some help, after parking one day tried to start again but starter just barely tries it never makes 1/4 rotationand stops. I am assuming all sensprs are made because it tries the voltage starts then goes to 11.5vdc on two batteries im thinking connections at starter does anyone have outher ideas.
/ 3032 help #2
Clean all battery cable connections for starters, what I'd suggest.
Then get the battery load tested.
If older than 4 years, suspect new one needed.
Dig deeper if still a problem. .....just my initial ideas..
/ 3032 help #3
I'll go along with "beenthere" but add you should be sure battery cables are properly tightened and trace your ground wire to the frame. Clean it and make sure it's tightned securely.
/ 3032 help #4
Have you tried to jump-start the tractor from another vehicle or a battery booster? If a jump-start works to start the engine, you need a new battery. If the jump-start does not work, look elsewhere for the issue with electrical cables, connections, starter motor.
Good luck!
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
iDrive TDS-2010H...
iDrive TDS-2010H...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
