303 Tractor Fluid
/ 303 Tractor Fluid #1
kasedian
Kansas
Ford 1900
Just wanted to know if anyone knows if this stuff is worth a carp. Can I use it instead of the Ford 134 fluid and be ok? Its on sale at Orschelns for $25 for 5 gallons. Thanks
Hydraulic Fluid
/ 303 Tractor Fluid #2
what does the specs on the can say?
does it meet M2C134D spec? Most generic UTF's do...
here you do.. i did your homewok for you..
•Manufactured from base oils selected for their purity and thermal stability, this product contains a premium additive package to provide wear protection and anti-oxidant properties while being compatible with O-rings, seals and packing materials.
•Contains extreme pressure additives to protect gears and working parts of pumps and hydraulic equipment.
•Excellent water separation and anti-foaming characteristics.
•Blends safely with all OEM fluids.
•May be used where the following fluids are recommended: AGCO, MF, White: PF821, M-1127, M-1129, Permatran®, Q-1722. Allison: C-3. Case/IH®: IH-143, -145, MS-1204, MS-120-5, MS-1206, Hy-Tran®. Caterpillar: TO-2. Ford, New Holland: ESN-M2C, 134B, C. John Deere®: j20A, B(Hy-Gard®), J14B (303), J14C.
It meets 134C spec., not the newest 134D spec.
what are you putting it in? Helps to mention that. If it's a ford / NH product from about 1998 or earlier.. it likely specs the 134C fluid...
if it's your ford 1979-1983 era model 1900 then it's more than fine.
soundguy
/ 303 Tractor Fluid
Thanks Soundguy. You are a wealth of information. Very pleasant, too.
207923 (A63290)
207923 (A63290)
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2006 Ford F-250...
2007 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2007 Nissan...
1501 (A65054)
1501 (A65054)
UNUSED SDLANCH 1RGC40 HIGH END MINI GOLF CART (A65055)
UNUSED SDLANCH...
2006 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2006 MAC 35ft...
