3020 steering issue, turns right
/ 3020 steering issue, turns right #1
Sberry
Platinum Member
Brethren, MI
Mostly green
I do have a manual but its quite tedious. The steering turns right on its own on occasion. The whole thing, the tractor is old and a bit wonky but everything else works, the 3 pt settles some and chatters on start up. I figure its something worked its way loose in the steering box.
/ 3020 steering issue, turns right #2
Eventually you will need to have the power steering box under the steering wheel overhauled.
/ 3020 steering issue, turns right #3
1st and easiest thing to do is renew o-rings in the steering motor under the fuel tank. This can be accomplished by removing frt axle & one side frame.
