3016 positive traction issue
   / 3016 positive traction issue #1
Walter L
Delhi LA
LS XG3135, Foton FT404,Farmtrac 555 ,Kubota L245H offset garden tractor Mahindra 2660 cab tractor
My 3016 wont go into positive traction, does anyone have the adjustment procedure?
Walt
   / 3016 positive traction issue #2
If you are talking about the diff lock I had a similar problem on my 2615HST. I couldn't get the pedal down with my full weight on it. From lack of use my diff lock linkage froze up (rusted). I had to soak all the linkage (mine went through the case from left to right side) with penetrating oil, Tap down on the pedal with a rubber mallet, lube again and pry up the pedal with a crowbar. I had to do this several times to get the lube into the linkage where it went through the case but eventually it freed up.
Not sure but I think your 3016 diff lock is like mine.
If your pedal does move freely the other thing I have seen on a friends tractor is the linkage stuck in the locked position and the owner busted a gear in one of the rear axle gear reduction housings because the axles were locked together when he made some sharp turns on a hard surface. Something had to give and it was the gears. Hopefully you don't have that problem.
Thank you George and i think i have the same problem your friend had sadly.
Walt
   / 3016 positive traction issue #4
Walt,
My friends tractor was a JD but I think the gear replacement would be similar. It was a fairly easy job to do. Once we took it apart to verify the problem we just had to look in the parts book and order the gears and a new housing gasket. If I recall, entire job took about two to three hours.
Thank you George that sounds like a job for next winter.
Wat
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2121 (A51244)
2121 (A51244)
1263 (A50490)
1263 (A50490)
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
