3000 Series A/C Issues
   / 3000 Series A/C Issues #51
IMO, to condense theses problems down to a single point...looks like having a knowledgable dealer is KEY to avoiding these problems...talked to another 3x20 cabbed owner who got his tractor from the same dealer as me and his is blows cold in the summer, hot in the winter...
These tractors are just ASSEMBLED by JD, and the dealer NEEDS to do the fine tuning & adjustments...on my 3520 the Cab Seal was torn AND the 3pt didnt lower all the way to the ground...Both issues I obviously didnt know existed on my tractor as it hadnt even been delivered yet...but both were found and fixed prior to delivery and my 3520 has been running like a Swiss Watch since it landed here on my property...
   / 3000 Series A/C Issues #52
You are very fortunate to have such a dealer close by. I doubt there are many like him. I won't go into the issues I've had.
Let me just say I'd pay more money for equipment to have such a dealer.
   / 3000 Series A/C Issues #53
Nuru said:
All, just for grins, which of these isolators and seals are you guys seeing that were defective/broken?
1 MIU10263 SEAL 1
2 MIU10444 SEAL
4 MIU10441 SEAL 1
5 MIU10443 SEAL 1
6 MIU10440 SEAL 1
7 MIU10570 SEAL 1
10 MIU10419 ISOLATOR 1
11 MIU10418 ISOLATOR 1
12 MIU10480 ISOLATOR 2
15 MIU10569 SEAL
Nuru, very interesting and excellent question. I'm anxious to remove my cab top and see if/what problems exist in the air box. However, I have a house full of company this week and won't get to it until next week (at the earliest). Exchanging info like this helps immensely with problems.
   / 3000 Series A/C Issues #54
ddivinia said:
It sure seems like JD is screwing these cabs up. They have such an opportunity to gain market share. I suspect Kubota is doing just fine with theirs. I tell ya, the New Holland smaller cab tractors are nice also.
D.
Darin, I agree with you 100%. JD has a pretty nice cab , ergonomics and feature wise. However, it seems the A/C and heating system on many of the 3000 series tractors has it's issues. For the kind of money they charge (and we pay) you'd think it would get fixed. Could be only a small percentage is having problems so JD isn't doing much about it.
   / 3000 Series A/C Issues #55
Silver_Knight said:
Minor???? Not to me.....Tell that to my dealer and Rep......they have spent about 40 hours on it, replaced freon twice, expansion valve twice and compressor once and it still doesn't cool. They have a new one on the lot that cools a few degrees cooler but nothing substantial.
"Silver_Knight, "Minor", well let me take a huge back step, they have done a bunch of work on your unit. hmm, they hopefully are going to Deere with this and will provide you a solution - seems like there is an air leak somewhere they have not found yet? Have they gone to step of checking how the dorrs seal, or if there is a leak in the lower window seals?
   / 3000 Series A/C Issues #56
No problem; I am going back in this weekend and will inspect the other seals and isolators, so that I can get an all in one request to my dealer.
   / 3000 Series A/C Issues #57
Mine passed inspection by my dealer but I had a valve fail 20 minutes into my first usage and I just caught the isolator seal breakage, before it got worse. But over all, the unit is performing well. i have 3 dealers within my range of travel and they all have decent/good service teams, so I consider myself lucky.
   / 3000 Series A/C Issues #58
1 MIU10263 SEAL 1
2 MIU10444 SEAL
4 MIU10441 SEAL 1
5 MIU10443 SEAL 1
6 MIU10440 SEAL 1
7 MIU10570 SEAL 1
15 MIU10569 SEAL
I removed the roof cap today on my 3720 and found isolator no. 10 broken at both rear corners, isolator no. 11 is missing, and seal no. 6 has a large crack.
I also measured the temperature of the large line at the evaporator with a thermocouple as suggested above and found it ranged from 47 deg F (compressor turned on) to 36 deg F (compressor turned off). I suspect this indicates the compressor, refrigerant, and etc is ok and it is further proof that the air leaks are the problem.
   / 3000 Series A/C Issues #59
Mine is missing seal 11 also... I am unsure if its a bad drawing or if most are missing that seal. The dealer sent me one for mine and I was unsure as weather to put it in or not. I did not and the ac is pretty good.
I was out 3 days ago on a 88 degree day and I had the AC on full tilt. I was very confortable and the steering wheel was cool. Wish I had a temp guage to give you numbers. I will say, it is no where neer as good as my truck AC, but it works well.
   / 3000 Series A/C Issues #60
I would probably fix the seal. 88 is not that hot. I think the some cabs have poor seals in the air box.
RHINO 160 - 5' ROTARY MOWER, 3PT (A54756)
RHINO 160 - 5'...
New Holland TS6.130 4WD 130HP Agricultural Tractor with Alamo Slope Mower (A55787)
New Holland...
1840 (A51248)
1840 (A51248)
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A54756)
UNUSED CFG...
