300 loader loose
/ 300 loader loose #1
uptaker73
Morganton, NC
RK 37, John Deere LX280 John Deere Z535m John Deere 160
I noticed this evening I had a wierd noise. Could not find it anywhere. Finally I seen it my loader arm on the left hand side where it sits on the tractor was loose. So loose I could move it by hand. It just rest there anyway but is there a adjustment for it. I have only used it about 15 hours.
/ 300 loader loose #2
Sounds like the dealer prep wasn't so good!
The torque values should be in your loader manual. I suggest you remove your loader, torque those bolts...do both sides while you're at it. Then go call your dealer and give him a piece of your mind.
If you torque wrench doesn't go high enough, let the dealer do it...I strongly suggest you torque, not just tighten, those bolts.
I suggest you not use the loader until that arm is torqued.
/ 300 loader loose #3
Are you talking about where the loader sit on the mount. If you are there is an adjustment. It is in your loader manual on page 40-8. You can disable the quick park and this will tighten them even more. I had the same problem on my 300CX on my 3320.
/ 300 loader loose
Yes it is where the loader sits on the tractor. I looked in the manual. I will try this adjustment tomorrow after work. If I tighten the cap screw it should put more down pressure on the rest if I'm looking at this right.
/ 300 loader loose
That adjustment worked. I just hope that I dont ever run out of adjustment.
