30' x 40' Barn with Lean - Build Progress
/ 30' x 40' Barn with Lean - Build Progress #41
I've not looked into it much, but my initial reaction/concern with the plastic sleeves I've seen used on pole barn posts is if water gets inside the sleeve it'll definitely keep moisture around the wood, whereas at least soil will drain/dry out eventually.
Exactly, post sleeves never really made any sense to me. They are just a place for water to stay forever, vs a nice sandy well-draining backfill around the posts that will shed it.
/ 30' x 40' Barn with Lean - Build Progress #42
I've looked into the sleeves, but I could not get to the buy point from the information on the various maker's websites.
The argument that the sleeve makers generally make is that the sleeve allows water to drain to the bottom quickly, and the post does not stay as wet as soil contact. They also claim that there is less fungal and insect intrusion. But no data.
I do notice that almost all of the pressure treated posts here that rotted out, rotted out only from the ground down 12-15". So while I am skeptical of the sleeve maker's claims, their zone of protection lines up with where our posts have had issues. 🤷‍♂️
All the best,
Peter
/ 30' x 40' Barn with Lean - Build Progress #43
Roadside power poles here last couple years have all gotten a fungus and wrap treatment. They've been in the ground for 30yrs. The crew digs down, wrap the post, drill two holes at ground level, injects fungicide, caps the holes then backfills.
/ 30' x 40' Barn with Lean - Build Progress #45
That is a nice build. Experience does make a difference. I hauled pole barn materials for a builder that had ten to maybe fourteen crews. The larger builds took more than one trip so I could see the progress. You look at enough buildings, you can easily pick up out little things. That and the speed of the build.
That was back around 2005. That company had a Perma-column franchise with their own batch plant to make them. At that time, it would add about 25% to the cost of a build.
/ 30' x 40' Barn with Lean - Build Progress #46
Ours get them about every four or five years here. The fungal treatment is a copper based material. Last time they were Heer, we got to chatting and they mentioned the oldest pole that they had serviced was from 1909, and still in great shape.
All the best, Peter
Need to catch up here; Day 8 (03Nov2025) progress:
  • Water line tapped into and hydrant located.
  • Electrical conduit placed into trench.
  • Trench for water run-off dug out; for compliance with downspout permit.
The last picture is from 04Nov2025, day 9.
/ 30' x 40' Barn with Lean - Build Progress #48
/ 30' x 40' Barn with Lean - Build Progress #49
Also, your weather must not get too cold. I have to bury my water lines at least 4 feet deep here.
The water line was buried about 42 - 45" with about 15" of covering on top. The electrical conduit was placed about 15 - 18" above the water line and covered up. I am in NE Ohio and we do get weather in the single digits on and off during winter. However, I do not believe there is any worry about freezing with the installation here.
/ 30' x 40' Barn with Lean - Build Progress #51
Ah, it looked alot shallower in the pics.
2019 Ford Fiesta SE Hatchback (A61574)
2019 Ford Fiesta...
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
2019 CATERPILLAR 259D3 SKID STEER (A64279)
2019 CATERPILLAR...
2016 John Deer 5075E (A60462)
2016 John Deer...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
