30 Series Engine Flaw
/ 30 Series Engine Flaw #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
My B-I-L has a 4430:
He overheard someone who seemed to know what he was talking about mention some type of inherent flaw in the 30 series engines. He's never had any trouble with his and he didn't hear any specifics. We're on vacation together and when I mentioned this web site he just wanted me to ask.
/ 30 Series Engine Flaw #2
That tractor is at least 30 years old. If you have not had a problem by now I would not worry about it.
Ken
/ 30 Series Engine Flaw #3
x2
if they'll go a year they'll go 100 more
nice looking machine
/ 30 Series Engine Flaw #4
My family and I use to own a 4430. It was a very very solid tractor, the only issues I remembered was the hydraulics were a bit weak and it was a bit cold natured. The 40 series were improved on both of these issues. That tractor had over 14,000 hours on it when we traded it in and it still dynoed over 175 horse. Its a good tractor to say the least.
Ken
Well, like I said, this was his question, not mine. He's not a member here, so he asked me to post it. I don't think he'll worry about it, he was just curious. He didn't say it but he may be more curious about how intelligent the guy was who made the remark about the 4430's engine.
/ 30 Series Engine Flaw #6
The 4430 tractor used the 404 cubic inch engine. This sam basic engine was used from 4020's in 1964 through the 4040 in 1982. It was one of the most reliable engines ever produced in my opinion. However, when the 4430 was introduced, a new, higher volume engine oil pump was installed that did cause some camshaft failures on early models. The drive gear on the camshaft was not hardened enough to handle the extra load. If these were going to fail, it usually happened early in life. It is fairly easy to check this by removing the tachometer drive housing from the right side of the engine block. The oil pump gear is very visible and the camshaft gear is directly behind it. If this gear wears too thin, it can shear off the teeth and lose oil pressure. Although this was a possible problem on early models I would not consider it a serious threat now. I don't recall seeing one fail for the past 15-20 years.
/ 30 Series Engine Flaw #7
Those problems were early on the run and for many they were covered under the warrantee. There also was issues with the transmission and they had an update for that.
Thanks guys. He bought the tractor used about 8 years ago. And he uses it hard, bailing hay, running fertilizer spreader, etc, and has had no problems.
/ 30 Series Engine Flaw #9
Thousands of these around here and were very good but even dealers will warn of head problems especially artics 8430-8630 i had a couple and were fine , My reason for "no more deere's" Was that inadequate hydraulic system whitch they continued for far too long ( comparing to ford or ih of same era )
But generally there are few better .
By artics you mean articulated models? What type of head problems and why with those specific types?
/ 30 Series Engine Flaw #11
Hey i'm not a green lover but have had many over the years and some 30 series " and i mean SOME" did suffer from blown head gaskets and warped heads but no worse than the old " Ford porous engine blocks" or " CAT v8 Head trouble " it is but a few . Why would there be so many being used ?
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
CATERPILLAR 299D3 SKID STEER (A64279)
CATERPILLAR 299D3...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2005 Ingersoll Rand 185 Towable Air Compressor (A61572)
2005 Ingersoll...
2022 EZ-GO ELITE...
Landa PGDC5-3500 (A64119)
Landa PGDC5-3500...
