3 spool hydraulic valve
/ 3 spool hydraulic valve #1
ptk
thunder bay, ontario
b2150
I have a 3 spool hydraulic valve that I use to run my backhoe. On spool # 1 (first one to receive power) I have a detent on it to provide continuous flow to the backhoe. On the second valve I run a hydraulic thumb. In order to run the thumb I must put valve 1 in neutral.
If I move the backhoe to valve 2 (moving the detent), and the thumb to valve 1, will the thumb have power if the detent in valve 2 is engaged (ie power to the backhoe)?
/ 3 spool hydraulic valve #2
I doubt that will work but you could try without swapping the detent by simply switching the hoses and manually hold the 2nd position and see if the 1st operates
/ 3 spool hydraulic valve #3
I think it would work but agree with Oldnslo - test it out how he's outlined. and report back! I'm curious to hear the outcome as I'll be doing something similar one day.
E.
Set of 4 Unused ST205/75R15 Radial Trailer Tires (A66734)
Set of 4 Unused...
Unused 2026 CID ITAKB72-SC 72in. Skid Steer Bucket Attachment (A66734)
Unused 2026 CID...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
2009 PETERBILT 388 FLATTOP SLEEPER (A67714)
2009 PETERBILT 388...
2007 Freightliner M2 106 T/A 3,150 Gallon Septic Wet Vacuum Truck (A66736)
2007 Freightliner...
1960 (A65054)
1960 (A65054)
