3 rear remotes on a John Deere 1026R
   / 3 rear remotes on a John Deere 1026R #21
That is a super nice job. Does it require a double flare and what did you make them with ?
Scott
Scott
Thank you.
They are regular 37 degree flares. I used a Mastercool hydraulic flaring tool to do the flares.
   / 3 rear remotes on a John Deere 1026R #23
Thank you.
What size tubing will fit the Imperial 370 tubing bender?
   / 3 rear remotes on a John Deere 1026R #25
So please tell me what you will use 3 remotes for? Top and tilt is 2. What about the 3rd??
   / 3 rear remotes on a John Deere 1026R #26
On a rear blade to adjust the angle of the rear blade. The top would adjust the angle of attack the tilt would adjust the blade to follow the ground as it lays and the blade angle adjusted by the 3rd.
On a box blade the usual top and tilt, and for the same reasons, and a 3rd for hydraulic rippers..
James covered it. I also plan to add a hydraulic dump trailer in the future.
   / 3 rear remotes on a John Deere 1026R #28
And in the OP's case, it's little more money to add 3 over 2. If he rarely uses the 3rd it's still better than needing a 3rd and it not be there. Go 3 every time money allows it.
Also it takes the same amount of fittings, line & time no matter if you are installing a 1 or 3 spool valve.
The total cost of the 3 spool install was still less than if I had got the John Deere single rear valve, plus I also have a power beyond that I would have been able to have with the JD rear valve.
   / 3 rear remotes on a John Deere 1026R #30
You did good Chevy!!!!
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2016 Nissan Pathfinder SUV (A55758)
2016 Nissan...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54756)
PREDATOR TRI-FUEL...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
