3 rear remotes on a John Deere 1026R
   / 3 rear remotes on a John Deere 1026R #21
That is a super nice job. Does it require a double flare and what did you make them with ?
Scott
Scott
Thank you.
They are regular 37 degree flares. I used a Mastercool hydraulic flaring tool to do the flares.
   / 3 rear remotes on a John Deere 1026R #23
Thank you.
What size tubing will fit the Imperial 370 tubing bender?
   / 3 rear remotes on a John Deere 1026R #25
So please tell me what you will use 3 remotes for? Top and tilt is 2. What about the 3rd??
   / 3 rear remotes on a John Deere 1026R #26
On a rear blade to adjust the angle of the rear blade. The top would adjust the angle of attack the tilt would adjust the blade to follow the ground as it lays and the blade angle adjusted by the 3rd.
On a box blade the usual top and tilt, and for the same reasons, and a 3rd for hydraulic rippers..
James covered it. I also plan to add a hydraulic dump trailer in the future.
   / 3 rear remotes on a John Deere 1026R #28
And in the OP's case, it's little more money to add 3 over 2. If he rarely uses the 3rd it's still better than needing a 3rd and it not be there. Go 3 every time money allows it.
Also it takes the same amount of fittings, line & time no matter if you are installing a 1 or 3 spool valve.
The total cost of the 3 spool install was still less than if I had got the John Deere single rear valve, plus I also have a power beyond that I would have been able to have with the JD rear valve.
   / 3 rear remotes on a John Deere 1026R #30
You did good Chevy!!!!
2019 Doosan LCV6W Towable LED Light Tower (A55851)
2019 Doosan LCV6W...
2006 GMC W5500 Dovetail Flatbed Truck (A55788)
2006 GMC W5500...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A55851)
2024 Wanco...
2021 Ram ProMaster City Van (A55788)
2021 Ram ProMaster...
UNUSED LANDHONOR 11' X 19' ALL-STEEL CARPORT (A54757)
UNUSED LANDHONOR...
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EFXFFA41510 (A54865)
2015 Ford F-150...
