3 rear remotes on a John Deere 1026R
   / 3 rear remotes on a John Deere 1026R #1
chevy
Platinum Member
East Central, Indiana
Kioti CK3510SE HST, John Deere X739
I got a 3 spool valve mounted on the rear of my John Deere 1026R.
It was not as difficult as I thought it would be. I removed the tool box & used those holes to mount a steel plate for the valve.
I supplied the rear valve by cutting into the supply line running to the rear power beyond & also tied into tank return line.
Steel tubing sure makes a cleaner install than hoses do.
   / 3 rear remotes on a John Deere 1026R #2
Nice install, looks good.
And people want factory install, why.
One gains knowledge and spends less money.
   / 3 rear remotes on a John Deere 1026R #3
Very nice install.
In this case JJ, I don't think he had a choice. Not sure they offer triple rear remotes on a 1026??
   / 3 rear remotes on a John Deere 1026R #4
chevy,
Very nice install, one of the best I have seen on TBN.
   / 3 rear remotes on a John Deere 1026R #5
Yup, great job :thumbsup:
Thank you. I never knew how handy a hydraulic top link could be, until I got one for my 4120. After that I had to have one on the 1026R.
I wish I had learned that years ago.
   / 3 rear remotes on a John Deere 1026R #7
Very nice install. You obviously have some experience bending steel tubing.:thumbsup:
   / 3 rear remotes on a John Deere 1026R #8
Nice work! The tubing looks perfect through the bends. How/What did you bend it with?
Over 30 years of working with plumbing & electrical helped in the bending.
I used an IMPERIAL, 370-FH tubing bender.
   / 3 rear remotes on a John Deere 1026R #10
I believe that JD does offer up to 2 rear remotes for those tractors. And yes it is a very clean installation. :thumbsup::thumbsup:
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A55218)
2021 NEW HOLLAND...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
SKID STEER QUICK ATTACH HYD COLD PLANER (A54756)
SKID STEER QUICK...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
