3 rear remotes on a John Deere 1026R
   / 3 rear remotes on a John Deere 1026R #1
chevy
Platinum Member
East Central, Indiana
Kioti CK3510SE HST, John Deere X739
I got a 3 spool valve mounted on the rear of my John Deere 1026R.
It was not as difficult as I thought it would be. I removed the tool box & used those holes to mount a steel plate for the valve.
I supplied the rear valve by cutting into the supply line running to the rear power beyond & also tied into tank return line.
Steel tubing sure makes a cleaner install than hoses do.
   / 3 rear remotes on a John Deere 1026R #2
Nice install, looks good.
And people want factory install, why.
One gains knowledge and spends less money.
   / 3 rear remotes on a John Deere 1026R #3
Very nice install.
In this case JJ, I don't think he had a choice. Not sure they offer triple rear remotes on a 1026??
   / 3 rear remotes on a John Deere 1026R #4
chevy,
Very nice install, one of the best I have seen on TBN.
   / 3 rear remotes on a John Deere 1026R #5
Yup, great job :thumbsup:
Thank you. I never knew how handy a hydraulic top link could be, until I got one for my 4120. After that I had to have one on the 1026R.
I wish I had learned that years ago.
   / 3 rear remotes on a John Deere 1026R #7
Very nice install. You obviously have some experience bending steel tubing.:thumbsup:
   / 3 rear remotes on a John Deere 1026R #8
Nice work! The tubing looks perfect through the bends. How/What did you bend it with?
Over 30 years of working with plumbing & electrical helped in the bending.
I used an IMPERIAL, 370-FH tubing bender.
   / 3 rear remotes on a John Deere 1026R #10
I believe that JD does offer up to 2 rear remotes for those tractors. And yes it is a very clean installation. :thumbsup::thumbsup:
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2017 Ford F-250 Crew Cab Pickup Truck (A55788)
2017 Ford F-250...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2019 International DuraStar 4300 24FT Box Truck (A55788)
2019 International...
FAKE (A52472)
FAKE (A52472)
