3 pt rear blade stand?
/ 3 pt rear blade stand? #1
Rob 80
WVA
B2650
My dad has a bush hog rear blade but it is missing it's stand. Is there a simple one i could buy?
I thought about just buying some galvanized pipe and drill holes into it for a pin but it needs a square bottom so it just don't sink into the ground.
/ 3 pt rear blade stand? #2
I have been using a 5 gallon bucket as a stand for my blade. That works fine but I do have to replace the bucket every few years.
/ 3 pt rear blade stand? #3
Put the whole thing on a skid, I'd think your tractor 3 pt will go low enough to reach the pins, mine does. Also keeps it out of the dirt or frozen to the ground in the winter.
/ 3 pt rear blade stand? #6
I use a tire changing jack from a 1954 Buick , works great.
/ 3 pt rear blade stand? #7
A pallet with strategically placed 4x4 blocks of wood, easily screwed/nailed into place, will provide a great holder for your rake.
I've done this for mine, and the pallet is on castor wheels for manoeuvrability on the concrete slab floor of my shed.
/ 3 pt rear blade stand? #8
This is the OEM stand on my Rhino 950. The blade weighs 1050#. I've found out, from experience, that the 3-point end of the blade is WAY too heavy to lift by hand. The stand is an important feature on my blade. Even though the pipe has a plate on the bottom - I'll set it on a chunk of plywood if the ground is soft.
/ 3 pt rear blade stand? #9
Yup that would work for stand,I used solid piece drill 6 holes 3" apart attach 3"x3" flat steel.
Dad was always big on not sitting the blade directly on the ground. Is there any real reason not to?
/ 3 pt rear blade stand? #11
Steel lying in dirt tends to rust faster. The weight of the blade creates a low spot - stays wet longer. At 62yo my blade should last my lifetime
t
/ 3 pt rear blade stand? #12
Rob80
I thought that my equipment was the only ones that grew fungi.
But I see yours does also.
/ 3 pt rear blade stand? #13
Just buy a piece of black pipe that sleeves in...Screw a cap on top. Screw a base mount flange to the base...
I did the same thing and made it so my stand slips out when I lift the rake to keep from bending it like I did to the original stand.
/ 3 pt rear blade stand? #14
When I back my tractor into its stall - the rear blade rests on two chunks of firewood. Not worried about rust. It's just too darn dry around here for things to rust. It sits on the firewood so, in the winter, it won't freeze to the ground. Without the wood chunks - the blade will pick up a pretty fair amount of frozen ground.
Rob80
Yeah i thought about power washing it but it's not like it affects anything.
/ 3 pt rear blade stand? #16
Several reasons no importance order
•the 3ph may not have gone low enough to attach or unattach at ground level
•if a quick hitch is used, you defeat the purpose at the get go
•saving back strain on heavy implements
•constant contact with moist soil and rust happens fast
•as soil gets moist, weighted items settle more—soon the implement pins are in the ground—they rust, are caked with mud, harder to lift
•if you want to keep a clean look around the implements (grass and weeds trimmed) it is much easier
/ 3 pt rear blade stand? #18
I just welded on a swing-up trailer jack stand making sure that it wasn't in the way of the swing arms.
/ 3 pt rear blade stand? #19
Just buy a piece of black pipe that sleeves in. 3/8” or 1/2”. Screw a cap on top. Screw a base mount flange to the base. Drill varying holes for height. Put in a clevis pin. Done.
I did exactly this (after I tried to drive off with the stand down). I used a black nipple painted yellow to match the blade color. Used a black cap on the top and a floor flange on the bottom. Drilled a bunch of holes and dropped in a clevis pin.
/ 3 pt rear blade stand? #20
Mine came with a kick stand that rotates close and clips in holder
Bobcat 873 (A55272)
Bobcat 873 (A55272)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
