3 pt rear blade stand?
   / 3 pt rear blade stand? #1
Rob 80
WVA
B2650
My dad has a bush hog rear blade but it is missing it's stand. Is there a simple one i could buy?
I thought about just buying some galvanized pipe and drill holes into it for a pin but it needs a square bottom so it just don't sink into the ground.
   / 3 pt rear blade stand? #2
I have been using a 5 gallon bucket as a stand for my blade. That works fine but I do have to replace the bucket every few years.
   / 3 pt rear blade stand? #3
Put the whole thing on a skid, I'd think your tractor 3 pt will go low enough to reach the pins, mine does. Also keeps it out of the dirt or frozen to the ground in the winter.
   / 3 pt rear blade stand? #6
I use a tire changing jack from a 1954 Buick , works great.
   / 3 pt rear blade stand? #7
A pallet with strategically placed 4x4 blocks of wood, easily screwed/nailed into place, will provide a great holder for your rake.
I've done this for mine, and the pallet is on castor wheels for manoeuvrability on the concrete slab floor of my shed.
   / 3 pt rear blade stand? #8
This is the OEM stand on my Rhino 950. The blade weighs 1050#. I've found out, from experience, that the 3-point end of the blade is WAY too heavy to lift by hand. The stand is an important feature on my blade. Even though the pipe has a plate on the bottom - I'll set it on a chunk of plywood if the ground is soft.
   / 3 pt rear blade stand? #9
Yup that would work for stand,I used solid piece drill 6 holes 3" apart attach 3"x3" flat steel.
Dad was always big on not sitting the blade directly on the ground. Is there any real reason not to?
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
Zero Turn Mower (A55853)
Zero Turn Mower...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
2005 Ford Explorer 4X4 SUV (A53424)
2005 Ford Explorer...
2014 Ford Escape (A50323)
2014 Ford Escape...
2025 JMR 40in Brush Grapple Skid Steer Attachment (A55851)
2025 JMR 40in...
