3 pt pipe puller??
/ 3 pt pipe puller?? #1
JohnnyD
Hey guys,
Does anyone make a 3 point pipe puller for installing underground irrigation pipe, cable, etc. Any help will be much appreciated. Thanks John.
/ 3 pt pipe puller?? #2
John, there have been a couple of threads on the subject. Most use a subsoiler attachment and fabricate either a "mole" to pull behind it (entire length of pipe/cable is moving through the soil) or a J-tube on the back side where the pipe/cable is fed through (cable doesn't move in the soil).
Here's one recent thread <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=projects&Number=154808&page=&view=&sb=&o=&vc=1>Under ground cable</A> /w3tcompact/icons/smile.gif
/ 3 pt pipe puller?? #3
Johhny
Further to the post shown below........
Attached is a photo of mine.
Slighter stronger and larger than the conduit version. Mine can do up to 40mm pipe (Have only tried 25mm to date but aim to do some 32mm tomorrow)
Works fine as long as the ground is soft. Ground here is like rock, but having just had some rain I aim to get into some tomorrow.
Cheers
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
JOHN DEERE GRAIN DRILL ROW MARKERS (A64280)
JOHN DEERE GRAIN...
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
