CoyPatton
Veteran Member
- Joined
- Aug 10, 2015
- Messages
- 1,660
- Location
- Poplar Bluff, MO
- Tractor
- Yanmar YM2002D with Koyker 110 FEL
Got it, thanks SR![]()
An open center valve allows for constant flow through the valve and a return to tank (reservoir). When you operate the valve you are doing several things usually, but here I will only focus on change of flow.
Potential issue is does the splitter use an open center valve?
If yes when it is connected and your tractor remote valve allows flow to the remote (pressurizing on of the 2 ports) then fluid will he returned to the tank as normal procedure of the valves and flow.
If not (open center) then depending on how long the tractor valve is open with flow stopped at the splitter’s valve, you could have a heat issue, damage hoses or lines, valves or many other components (O-rings) and tight tolerances in valves being a couple of biggies.
My guess would be the splitter valve is an open center.
