3 pt lift valve
/ 3 pt lift valve #1
Mallard1
Arkansas
John Deere 4320
I have a Belarus 65hp 570. When in position control mode with an attachment hooked up and lifted in the air I can hear a squealing coming from the valve. If I let it down just a little it will be quiet about 10 seconds then start again.
In select control mode where the lever stays in the center to hold position and you raise or lower the lever to adjust height it is always moving ever so slightly and also squealing.
I have pulled the pressure relief valve and cleaned and checked for proper pressure.
What I believe is happening is that the spool is letting fluid by.
It has a husco 5000 series valve bank on it. This is the information from the end of the valve where the fluid enters and exits:
G95D398 04
900021HV
5000-D 201 D
I said all of this to say what type of valve would this be? 3 position 4 way spring center model 5002-a1? Thanks for the help?
