3 pt lift hydraulic parts needed
   / 3 pt lift hydraulic parts needed #1
grafpatrick
Sanibel, FL
YM2200
Hello-
I have a ym 2200 with a dying 3 pt lift. The internal hydraulic ram sleeve shows pitting. Anyone have a replacement or a lead? Thanks.
John Churchill
Sanibel, FL
   / 3 pt lift hydraulic parts needed #2
Are you sure that pitting is causing your problem? I would change that fluid and clean the screen again.
No I am not certain and I am a bit concerned as the pitting seems to be at the end of the sleeve, so maybe should not affect performance until the lift is all the way up, but when I opened it up the screen was clean and the fluid looked good. Previous fluid/screen service improved, but did not completely correct the problem. There has been an gradual decline in performance since. I guess I still wonder about the valve mechanism and the seals in the piston. I have little experience with hydraulics, but the no performance at idle and weak performance at full throttle make me think of a leak in the ram rather than a valve problem.
   / 3 pt lift hydraulic parts needed #4
Have you checked the pressure from the pump? That would give the same problems you describe.
Front end loader works fine suggesting pump is OK
   / 3 pt lift hydraulic parts needed #6
I can supply used parts for your tractor , if needed. Probably new oring parts also. I would suspect the pitting has damaged the seals.
   / 3 pt lift hydraulic parts needed #7
The first thing I wondered was do you have a fel. When I read that you did I am wodering if you have enough hyd fluid?
Those fel lines, cylinders hold a lot of fluid. You may just be low on fluid if you only added the recommended amount without the frontend loader. I think my powershift has a dipstick? Check out the simple stuff first......
UNUSED MOWER KING ECSSTR072-72" HYD TILLER (A51248)
UNUSED MOWER KING...
2017 Nissan Titan SV Crew Cab Pickup Truck (A51692)
2017 Nissan Titan...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51248)
UNUSED FUTURE MINI...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
2006 CATERPILLAR 345CL EXCAVATOR (A51246)
2006 CATERPILLAR...
