3 pt lift hydraulic parts needed
   / 3 pt lift hydraulic parts needed #1
grafpatrick
Sanibel, FL
YM2200
Hello-
I have a ym 2200 with a dying 3 pt lift. The internal hydraulic ram sleeve shows pitting. Anyone have a replacement or a lead? Thanks.
John Churchill
Sanibel, FL
   / 3 pt lift hydraulic parts needed #2
Are you sure that pitting is causing your problem? I would change that fluid and clean the screen again.
No I am not certain and I am a bit concerned as the pitting seems to be at the end of the sleeve, so maybe should not affect performance until the lift is all the way up, but when I opened it up the screen was clean and the fluid looked good. Previous fluid/screen service improved, but did not completely correct the problem. There has been an gradual decline in performance since. I guess I still wonder about the valve mechanism and the seals in the piston. I have little experience with hydraulics, but the no performance at idle and weak performance at full throttle make me think of a leak in the ram rather than a valve problem.
   / 3 pt lift hydraulic parts needed #4
Have you checked the pressure from the pump? That would give the same problems you describe.
Front end loader works fine suggesting pump is OK
   / 3 pt lift hydraulic parts needed #6
I can supply used parts for your tractor , if needed. Probably new oring parts also. I would suspect the pitting has damaged the seals.
   / 3 pt lift hydraulic parts needed #7
The first thing I wondered was do you have a fel. When I read that you did I am wodering if you have enough hyd fluid?
Those fel lines, cylinders hold a lot of fluid. You may just be low on fluid if you only added the recommended amount without the frontend loader. I think my powershift has a dipstick? Check out the simple stuff first......
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2018 JOHN DEERE 333G SKID STEER (A51246)
2018 JOHN DEERE...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2020 CATERPILLAR 299D3 SKID STEER (A51246)
2020 CATERPILLAR...
