3 pt lift hydraulic parts needed
   / 3 pt lift hydraulic parts needed #1
grafpatrick
Sanibel, FL
YM2200
Hello-
I have a ym 2200 with a dying 3 pt lift. The internal hydraulic ram sleeve shows pitting. Anyone have a replacement or a lead? Thanks.
John Churchill
Sanibel, FL
   / 3 pt lift hydraulic parts needed #2
Are you sure that pitting is causing your problem? I would change that fluid and clean the screen again.
No I am not certain and I am a bit concerned as the pitting seems to be at the end of the sleeve, so maybe should not affect performance until the lift is all the way up, but when I opened it up the screen was clean and the fluid looked good. Previous fluid/screen service improved, but did not completely correct the problem. There has been an gradual decline in performance since. I guess I still wonder about the valve mechanism and the seals in the piston. I have little experience with hydraulics, but the no performance at idle and weak performance at full throttle make me think of a leak in the ram rather than a valve problem.
   / 3 pt lift hydraulic parts needed #4
Have you checked the pressure from the pump? That would give the same problems you describe.
Front end loader works fine suggesting pump is OK
   / 3 pt lift hydraulic parts needed #6
I can supply used parts for your tractor , if needed. Probably new oring parts also. I would suspect the pitting has damaged the seals.
   / 3 pt lift hydraulic parts needed #7
The first thing I wondered was do you have a fel. When I read that you did I am wodering if you have enough hyd fluid?
Those fel lines, cylinders hold a lot of fluid. You may just be low on fluid if you only added the recommended amount without the frontend loader. I think my powershift has a dipstick? Check out the simple stuff first......
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
UNUSED FUTURE 19" EXCAVATOR RAKE (A51248)
UNUSED FUTURE 19"...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
HOMEMADE TREE STAND W/ STEPS (A51248)
HOMEMADE TREE...
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
