3 pt lift hydraulic parts needed
   / 3 pt lift hydraulic parts needed #1
grafpatrick
Bronze Member
Sanibel, FL
YM2200
Hello-
I have a ym 2200 with a dying 3 pt lift. The internal hydraulic ram sleeve shows pitting. Anyone have a replacement or a lead? Thanks.
John Churchill
Sanibel, FL
   / 3 pt lift hydraulic parts needed #2
Are you sure that pitting is causing your problem? I would change that fluid and clean the screen again.
No I am not certain and I am a bit concerned as the pitting seems to be at the end of the sleeve, so maybe should not affect performance until the lift is all the way up, but when I opened it up the screen was clean and the fluid looked good. Previous fluid/screen service improved, but did not completely correct the problem. There has been an gradual decline in performance since. I guess I still wonder about the valve mechanism and the seals in the piston. I have little experience with hydraulics, but the no performance at idle and weak performance at full throttle make me think of a leak in the ram rather than a valve problem.
   / 3 pt lift hydraulic parts needed #4
Have you checked the pressure from the pump? That would give the same problems you describe.
Front end loader works fine suggesting pump is OK
   / 3 pt lift hydraulic parts needed #6
I can supply used parts for your tractor , if needed. Probably new oring parts also. I would suspect the pitting has damaged the seals.
   / 3 pt lift hydraulic parts needed #7
The first thing I wondered was do you have a fel. When I read that you did I am wodering if you have enough hyd fluid?
Those fel lines, cylinders hold a lot of fluid. You may just be low on fluid if you only added the recommended amount without the frontend loader. I think my powershift has a dipstick? Check out the simple stuff first......
PAIR OF FRAME MOUNTS FOR VACUUM PUMPS (A53843)
PAIR OF FRAME...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
MONOSEM NG-3 LOT NUMBER 231 (A53084)
MONOSEM NG-3 LOT...
WOODWAY ELECTRIC TREAD MILL (A51248)
WOODWAY ELECTRIC...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
