3 pt hitch stuck
/ 3 pt hitch stuck #1
wildandfree
garner nc
farm pro 2420
put fluid in after washer blows now 3 pt hitch up will not lower cannot turn knob for the adjustment and ideas
/ 3 pt hitch stuck #2
Which way did you turn the knob?
Counterclockwise will open the valve and adjust the descent rate.
Clockwise will lock the 3pt for transport.
Sometimes parts rust up and jam things.
Remove the screw rod and knob and see if any fluid comes out.
/ 3 pt hitch stuck #5
Did you activate the 3pt lever to see if the relief would come on?
There might be other parts in the hole, if not a needle valve.
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
YALE FORKLIFT (A63291)
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
