3-Point Hitch 3 Pt Hitch Stuck in Full Up
   / 3 Pt Hitch Stuck in Full Up #31
The same thing happend to me this spring and thankfully it was only the knob. A good thing is once it happens, you'll never forget how to "fix" it!
   / 3 Pt Hitch Stuck in Full Up #32
thank you all for the posts, it was the knob...whew!
   / 3 Pt Hitch Stuck in Full Up #33
Same situation happened to me a couple hours after the dealer dropped the tractor off at my house. I could not get the 3 pt lift arms to lower - got very frustrated and called my neighbor who has a kioti ck27. He couldn't figure it out either. Finally, as I was playing around, I pushed the draft control lever down and I realized that the 3 pt arms lowered simultaneously. I felt a little foolish, but I learned something.
BTW, I am very grateful to all the posters on TBN, as I have learned so much. The information I have learned here has prevented other such "situations".
   / 3 Pt Hitch Stuck in Full Up #34
The 3 point hitch speed control is frozen. I even tried turning it with a pair of Chennek locks with no luck. Is there something I'm doing wrong ?
   / 3 Pt Hitch Stuck in Full Up #35
Try a product similar to PB Blaster over several days to weeks. Spray, gently try to rotate, repeat.
They seize from lack of use.
   / 3 Pt Hitch Stuck in Full Up #36
I'll try that. Thanks
WACKER NEUSON LIGHT TOWER (A55745)
WACKER NEUSON...
2011 GAYLEAN  130 BBL VACUUM TRAILER (A55745)
2011 GAYLEAN 130...
John Deere 7130 (A53314)
John Deere 7130...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
1999 INTERNATIONAL 4700 24FT BOX TRUCK (A56138)
1999 INTERNATIONAL...
