3-Point Hitch 3 Pt Hitch Stuck in Full Up
   / 3 Pt Hitch Stuck in Full Up #31
The same thing happend to me this spring and thankfully it was only the knob. A good thing is once it happens, you'll never forget how to "fix" it!
   / 3 Pt Hitch Stuck in Full Up #32
thank you all for the posts, it was the knob...whew!
   / 3 Pt Hitch Stuck in Full Up #33
Same situation happened to me a couple hours after the dealer dropped the tractor off at my house. I could not get the 3 pt lift arms to lower - got very frustrated and called my neighbor who has a kioti ck27. He couldn't figure it out either. Finally, as I was playing around, I pushed the draft control lever down and I realized that the 3 pt arms lowered simultaneously. I felt a little foolish, but I learned something.
BTW, I am very grateful to all the posters on TBN, as I have learned so much. The information I have learned here has prevented other such "situations".
   / 3 Pt Hitch Stuck in Full Up #34
The 3 point hitch speed control is frozen. I even tried turning it with a pair of Chennek locks with no luck. Is there something I'm doing wrong ?
   / 3 Pt Hitch Stuck in Full Up #35
Try a product similar to PB Blaster over several days to weeks. Spray, gently try to rotate, repeat.
They seize from lack of use.
   / 3 Pt Hitch Stuck in Full Up #36
I'll try that. Thanks
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2008 Ford Fusion SE Sedan (A55853)
2008 Ford Fusion...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
