3-Point Hitch 3 Pt Hitch Stuck in Full Up
   / 3 Pt Hitch Stuck in Full Up #31
The same thing happend to me this spring and thankfully it was only the knob. A good thing is once it happens, you'll never forget how to "fix" it!
   / 3 Pt Hitch Stuck in Full Up #32
thank you all for the posts, it was the knob...whew!
   / 3 Pt Hitch Stuck in Full Up #33
Same situation happened to me a couple hours after the dealer dropped the tractor off at my house. I could not get the 3 pt lift arms to lower - got very frustrated and called my neighbor who has a kioti ck27. He couldn't figure it out either. Finally, as I was playing around, I pushed the draft control lever down and I realized that the 3 pt arms lowered simultaneously. I felt a little foolish, but I learned something.
BTW, I am very grateful to all the posters on TBN, as I have learned so much. The information I have learned here has prevented other such "situations".
   / 3 Pt Hitch Stuck in Full Up #34
The 3 point hitch speed control is frozen. I even tried turning it with a pair of Chennek locks with no luck. Is there something I'm doing wrong ?
   / 3 Pt Hitch Stuck in Full Up #35
Try a product similar to PB Blaster over several days to weeks. Spray, gently try to rotate, repeat.
They seize from lack of use.
   / 3 Pt Hitch Stuck in Full Up #36
I'll try that. Thanks
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
Cushman Cart (A55853)
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A55745)
2012 GALLEGOS 130...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
