Grapple 3-pt hitch log grapple
/ 3-pt hitch log grapple #2
The link looks interesting, but I'd want to see more info before even considering buying. They really need to put some pictures of it in action on the web site and some specs (lift capacity, max and min diameter logs it can handle, for example).
John Mc
John Mc, I agree with your assessment. I was hoping someone on this forum might have more information about the log grapple. There doesn't seem to be any information out there on the internet.
MSWoodlot
/ 3-pt hitch log grapple #4
Looks like a good idea, except I don't see a swivel in the design. It's gotta have a swivel, or going around corners with the log will make the tractor steer hard or the log to get all gouged back and forth at the grip area. Actually, it needs to swivel fore and aft and side to side too, or similar gouging will happen. Basically, the grapple part should hang from a swivel fitting like found on chain hoists (or maybe it is just a few links of chain). Seems like I saw this on a full-size skidder. Here is a pic... when I saw this thing working, the grapple was swinging all over the place. I want to build one of these anyway, maybe I shoud give it some more serious thought. Will let you know what I come up with.
/ 3-pt hitch log grapple #5
Seems more complicated than it needs to be. We moved telephone poles with simple tongs on our pole truck. Why not make a basic pair of tongs on a swivel? I realize the primary drawback is that it would require getting off the tractor or using two people, but that thing looks super expensive.
Here's some additional information from the Mississippi Market Bulletin. The "Grappler" does swivel. Still no cost data though.
MSWoodlot
Page 28 MISSISSIPPI MARKET BULLETIN February 1, 2006
Edited By Andy Prosser
A local Make Mine Mississippi company has developed an efficient
means to assist area landowners to transport small diameter timber by
way of a grapple system for small farm tractors. The BPG
Corporation of Columbia, Mississippi, designs and builds innovative
tractor implements for managing timber for independent operators.
This new method reduces labor, waste, damage, and cost with
increased productivity for Mississippi landowners who like to
“do it yourself.” In response to the needs created by the recent hurricanes,
this grappling system has become a perfect fit for cleanup duty
and juvenile pine recovery. BPG's CEO, founder and master
innovator, Sidney K. Burch, was determined to solve the problems
he was encountering for the operator of the smaller farm vehicle in
managing timber handling safely and efficiently in a cost
effective manner. Sidney has decades of farming and business experiences
to provide the understanding of the problems and the people
involved in tree farming. His vision of such drives the
designs, fabrication, and testing of each new grapple. Most notably,
Sidney's prior innovations brought to the market the Burch Plantation
Grappler ™, an efficient, compact hydraulic timber grappler designed
for the smaller tractor or truck vehicle operation usable by the
individual. In the initial designs, the Burch Plantation Grappler ™ was
manufactured for creating and m a i n t a i n i n g clean tree rows on established farms and for the removal of pine plantation
thinnings. To have the lowest costs possible for the individual
agricultural operator, the grappler was designed as simply as possible
with the fewest movable parts. However, the hurricane season of
2005 brought a new challenge to area tree farmers. The conditions of
the tree farms after the storms require a different piece of equipment
needing the capability to swivel. Prior swiveling grapplers typically
had two hydraulic cylinders and four hydraulic lines and were
usually attached to large scale equipment. Such systems are also typically
higher priced and have more maintenance costs than desired by the
smaller tree farmer. Sidney once again has responded by designing a
grappler that maintains the original one cylinder, two-line design but
has a simplified swiveling capability of a less complicated, lower maintenance
design for smaller farm equipment than the prior more
expensive swiveling grappler. So, if you are interested in the
Burch Plantation Grapple ™ for your property or farm, please contact
the BPG Corporation at 601-736-3372.
/ 3-pt hitch log grapple #7
MSWoodlot
Still no cost, but I turned up a couple of pictures of it, and it does not appear to have a swivel.
SmugMug
tlbuser,
Thanks for posting the photos.
I was basing my comment on swivel capability from the writeup in the Mississippi Market Bulletin--"Sidney once again has responded by designing a grappler that maintains the original one cylinder, two-line design but has a simplified swiveling capability of a less complicated, lower maintenance design for smaller farm equipment than the prior more expensive swiveling grappler."
But the photos you posted certainly don't suggest that the grapple swivels. Perhaps there are different models? I'm still curious about what these grapples cost.
MSWoodlot
/ 3-pt hitch log grapple #10
/ 3-pt hitch log grapple #11
I see the "Simplified Swivel". In the one picture from the tractor side view, up top of the grapple there is a chain, hanging somewhat loose. Below that, 10-12 inches down there is a large thru-bolt head showing. The grapple apparently can swivel fore and aft on this bolt, limited by the small chain. After thinking about it more, there is no reason the grapple has to turn with the log (like if the log tries to spin in the grapple), the log can turn on its own long axis to follow the tractor's rolling action on the ground. Now, if I am not confusing you, the OTHER way, turning the tractor to follow the trail around corners thru the woods, there you still need a swivel in the grapple. Otherwise it would be like pulling a trailer bolted solidly to the drawbar, no ability to turn on the hitch pin. The log would swing widely each way, or be gouged by the grapple. For firewood you may not care. I like the way the two grapple arms are "geared" together with those giant teeth. One cylinder that way. Hopefully it works well, and doesn't bind.
Thanks for all the useful information on 3-pt hitch hydraulic log grapples. But with prices exceeding $1,000, a buyer would have to do some serious log skidding. I like N80's advice, and will stick with log tongs and a chain for under $100.
MSWoodlot
/ 3-pt hitch log grapple #14
If you can see the hook up it is nothing more than 2 shackles hooked together. Either 2 regular shackles or 1 reg & 1 twisted. It is really a simple concept that would be easy to make for a few hundred dollars if you bought everything new. It would cost less if you had the steel and a cylinder.
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
Yanmar YM135 (A64127)
Wolverine 84" Quick Attach Snow Push (A66285)
Wolverine 84"...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A63688)
2022 Schulte...
2007 Freightliner Semi Truck (A66285)
2007 Freightliner...
