3 point troubles
/ 3 point troubles #1
dbl A ron
Kubota L295DT
I have a kubota L295DT with loader, just recently i was rottertilling and when i was finished i went to lift the implement but it wouldn't raise. after trying a few times i noticed the top adjustable bar pin had come out half way and jammed it from moving up. Ok now thats the story and here is the symptoms. the 3 point won't lift unless at high idle and it won't lift my weight (230lbs). i added fluids and that did nothing. the loader and pto work fine can anyone tell me what i broke and how to fix it. thanks
/ 3 point troubles #2
Have you changed the filter? If this has a filter like the L245 it could be that simple.
/ 3 point troubles
nope but i will now thanks for your quick responce.
/ 3 point troubles #4
Is there knob/valve of some sort lets hyd. fluid follow to 3pth might of turn off/half way open...knob/handle on some models can be found under seat area.
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
2013 John Deere 1770NT Planter (A63109)
2013 John Deere...
Finn KR8P Straw Chopper/Crimper (A64047)
Finn KR8P Straw...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
John Deere 6125R Tractor (A64047)
John Deere 6125R...
